camaro's a/c suxs
Old Jul 2, 2004 | 05:05 PM
DontMixWithRice's Avatar
camaro's a/c suxs
and thats final.
i have a 3.4l but the lt1 has the same system.
ne1 else having problems wiht it?
my problem is simple. the air blows cold when i first turn it on, but then it gets hot after a while. whether im in stand still traffic, or even on the highways.
ne suggestiosn?
__________________
Old Jul 2, 2004 | 05:09 PM
Metlhed54's Avatar
maybe you just need a recharge. my system works perfect and is ice cold and i have a 93 lt1 with all original parts. so i guess it just varies for these cars.
Terran2k's Avatar
I dunno, i had the reverse problem....started out warmish, then got colder over time, turned out was low on freon. had it checked for leaks with that dye and such, but no leaks or anything, just low on the freon. had it filled up and its freezing cold .
Old Jul 2, 2004 | 05:27 PM
1984camaroz28's Avatar
I had it but my headers cooked the AC
Old Jul 2, 2004 | 07:26 PM
CamaroBoy96Z28's Avatar
Mine worked great even when the compressor started leaking. Yet, its really nice not having the a/c in the way now.
Old Jul 4, 2004 | 12:17 PM
slopokrodrigez's Avatar
Your charge is low and the evaporator is freezing over or your TX valve is stuck.
Checking system pressure will tell you.
Old Jul 4, 2004 | 12:21 PM
jchevy's Avatar
My A/C works great, feels like a brand new cars A/C even here in AZ where it is 100+ degrees everday in the summer time.
Old Jul 4, 2004 | 12:22 PM
Hyperspeed97z28's Avatar
What should the a/c pressure's be ??
I'm about 35 on the low side and around 250 on the high side..
This is with the ac on MAX and fan setting HIGH....
my air is COLD
HectorM52
Jul 30, 2017 11:46 AM
alphaauto
Jan 23, 2015 07:42 AM
CaRParts102
Dec 6, 2014 08:45 AM
pologreen97z
Dec 2, 2014 10:42 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
