Camaro 94 z28 2.73 to 3.90 gears.
Old Oct 13, 2014 | 02:26 PM
ANGEL Z28's Avatar
Hello, i have 1994 z28 with 2.73 gears, i just got my new set from Summit. MGR-G875390 (3.90) I also got my RAT-108K INSTALLATION KIT 7.5 GM
A friend of mine told me that i will need a spacer, its that correct? What else should i buy?
thank you so much for your help!
Old Oct 13, 2014 | 02:32 PM
Re: Camaro 94 z28 2.73 to 3.90 gears.
3.08 and numerically lower factory rear axles come with a 2-series carrier. 3.23 and numerically higher come with a 3-series carrier. The gear set you linked is for a 3-series carrier, so you need a spacer and bolts to install that gear set in your 2-series carrier.
Old Oct 13, 2014 | 03:30 PM
ANGEL Z28's Avatar
Thank you!!!
Does this one will do?
MGR -075050(summit)
Sent from my Desire HD using Tapatalk 2
Old Oct 13, 2014 | 03:42 PM
ANGEL Z28's Avatar
This item?does it works?
Old Oct 13, 2014 | 03:59 PM
That's it.
Old Oct 13, 2014 | 05:17 PM
ANGEL Z28's Avatar
Thanx!
Old Nov 4, 2014 | 07:01 AM
ANGEL Z28's Avatar
I just did finished the job today, but it does have a sound. Its that normal?
Old Nov 4, 2014 | 08:40 AM
What kind of "sound"? Is it a "howl"? Means the gears aren't set up very well. Did you do it yourself or have a shop do it? I've been working on cars for 50 years, and wouldn't even attempt to set up my own gears.
Old Nov 4, 2014 | 01:33 PM
ANGEL Z28's Avatar
No, i did not do it myself, took it to a shop. They had to use a spacer, the guy told me that he has done this setup 10000 times, but never from 2.73. He was a little concern about the "sound", but he told me that, the oil needs to be changed after 300miles, so he will check it out again. But i am a little worry.
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
tds1213
Nov 27, 2014 12:55 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
