cam wear?
Old Jul 15, 2004 | 05:07 PM
PooHoopy's Avatar
Lightbulb cam wear?
How possible is it for a new cam to wear at the lobes with lifters that have 71K on them? solid roller cam 227/233 lift! Any insights on this would be great!
Old Jul 15, 2004 | 05:48 PM
PooHoopy's Avatar
TTT
Old Jul 15, 2004 | 06:41 PM
Dave88LX's Avatar
Check the "abuse of ttt" sticky at the top of the page
As for the cam, as long as your lifters are not damaged or worn, I don't see how it could cause any problems with the new cam. It's not like a flat tappet lifter/cam setup where it makes a wear pattern.
it is possiible that you have been running crappy/junked oil, or something to that effect, or the lifter rollers stuck somehow...I had a couple lifters like that.
Old Jul 16, 2004 | 11:18 AM
PooHoopy's Avatar
Thanks!
Old Jul 16, 2004 | 11:40 AM
Mindgame's Avatar
Did you check the lifters?
Could be some damage that keeps the rollers from rolling like they should. Don't see it happen much but anything is possible.
You say solid lifter cam? So you're replacing a solid cam with a new one and using the old solid lifters?? 71k... is that the number of miles on the lifters or the engine itself???
-Mindgame
Old Jul 16, 2004 | 03:05 PM
PooHoopy's Avatar
71K ON BOTH THE LIFTERS AND ENGINE!
Old Jul 16, 2004 | 03:08 PM
Mindgame's Avatar
Those lifters are way past rebuild time then. What brand?
-Mindgame
92_RS_305
Apr 19, 2015 01:45 PM
PROJECT X
Apr 17, 2015 12:13 AM
QuickSilver02
Apr 7, 2015 11:12 AM
8T8IROC
Mar 26, 2015 09:02 PM
