cam too big?
Old Feb 4, 2004 | 09:59 PM
will62085's Avatar
cam too big?
i am building a 383 forged, 200 shot, and was going with a xe236 (230/236 dur. - .544/.555 lift - 112 lsa) cam, but found a deal for a custom grind cam (242/248 dur. - .540/.563 lift - 110 lsa) ...car will have stock heads for about 6k miles till i can afford porting them ...what do you guys think? i like all the specs except for the 110 lsa, i dont wanna turn that many rpms...other mods in sig on the 95 m6
Old Feb 4, 2004 | 10:16 PM
97WS6SCharged's Avatar
Your unported heads are going to strangle that 383 no matter which cam you use. I would port the heads, and then pick a cam to match, or better yet, have someone grind a cam to match the heads.
Old Feb 4, 2004 | 10:22 PM
will62085's Avatar
i know the cam is too big for stock heads, but i cant afford to do the heads now, nor buy two cams for in the future, the heads will be ported probably at the end of this summer, but the car needs a motor in it, and im not changing the cam with the heads...
Old Feb 4, 2004 | 10:47 PM
It might be hard to live with for a while and will need some attention to tuning to make it drivable. That 110 is going to sound pretty mean.
Old Feb 4, 2004 | 10:48 PM
dobe's Avatar
custom grind as in it was a custom grind for someone elses car and you are buying used?
I wouldnt do that, get a cam for your setup. Get the heads now... if you cant afford it then hold off... no need to do things half assed. Then call up your preferred cam company (IE Isky, Comp, etc) and tell them your info and have a custom grind made for your setup.
-Santore
Old Feb 4, 2004 | 10:49 PM
will62085's Avatar
yeah i know, im thinking ill go with the xe236, or mabye even the xe230
Old Feb 4, 2004 | 11:31 PM
will62085's Avatar
-Santore
yes its a custom grind for an idetical setup as mine, except for ported heads...hasnt been in a motor yet
im asking peoples opinions on it this cam will be too big for a streetable car with my setup...not opinions on what i should spend my money on, not how i should build my motor
building a motor for ported heads, running stock heads temporarily, and putting on ported heads in 5 months is not half assed, im spending the money for the forged parts and all the good stuff, so now i cant afford heads just yet, but a head swap is a piece of cake, alot easier than rebuilding a motor cause its got ported heads and cast bottom end and blew up, and holding off is not an option, i need a car for school, and i have to get this on the road, the only way i can get a forged 383 in it, is to lay off on the heads for a few months...if not, i will be replacing it with a stock motor, untill im ready to put the 383 in it, so i may as well do it now
Old Feb 4, 2004 | 11:52 PM
Brandon 95 Z28's Avatar
Im guessing this is your daily driver? The cam would probably have to have a decent tune to be streetable. However you do have the advantage fo the extra cubes, so I htink besides possible ****ty brakes and some cam surge you might be OK. What gears will you be running?
Brandon
Old Feb 5, 2004 | 06:48 AM
dobe's Avatar
Didn't fully understand your question, I thought you were asking about the cam because you said the only thing you didnt like about the cam was the 110lsa.
but
...in that case... like others said have it tuned and it wont be that much of a problem....
Old Feb 5, 2004 | 08:05 AM
kmook's Avatar
Advanced Tech Moderator
I still wouldnt run it since you said you dont want to turn that many rpms... (I dont exactly know how much is to much since you didnt specify a actual # though).
Old Feb 5, 2004 | 12:38 PM
will62085's Avatar
the car has 4.10's in it, but i dont think i really want to deal with the loss of power brakes and stuff, ill probably go with a smaller cam...thanks guy for your input
Old Feb 5, 2004 | 01:01 PM
95Bird's Avatar
A wise man once told me " you never have too much cam...just not enough motor"
Old Feb 5, 2004 | 01:30 PM
Don 97 SS's Avatar
That's ripe! ROTFLMAO
On the other hand Confucious has been heard to say, "nature delights in punishing the fool who over cams an engine"
Old Feb 5, 2004 | 01:35 PM
rskrause's Avatar
Moderator
LOL
It's way to much cam for a stock head motor. A bad mismatch. You will not be happy, IMHO.
Rich Krause
Old Feb 5, 2004 | 02:40 PM
Mikey97Z's Avatar
Re: cam too big?
Originally posted by will62085
i am building a 383 forged, 200 shot .... custom grind cam (242/248 dur. - .540/.563 lift - 110 lsa)
That doesn't seem like a good nitrous cam to me. Only 110 lsa with 242/248 duration sounds like lots of overlap.
