cam swap wont idle
Old Jan 12, 2014 | 05:05 PM
SuperSportSS's Avatar
cam swap wont idle
just swapped the cam in my 1993 z28 and it will not idle on its own,
i know everyone is going to say go get a tune and go from there, but i first started it and it idled just fine on its own but the rockers werent adjusted correctly, so it wasnt running on all 8 cyl, so i adjusted them ( probably not right) and it wont idle now,
can someone tell me how to adjust these rockers without the engine running? ill post a video of what its doing, and how i have to keep it running.
i know the timing isnt off at all, i made sure when i put it together it was lined up correctly, so i know you guys know your stuff so lets see if we cant fix this thing. thanks
Old Jan 13, 2014 | 04:35 PM
Kevin Blown 95 TA's Avatar
Re: cam swap wont idle
You can read how to do it here.
4th Gen LT1 F-body Tech Articles
Old Jan 13, 2014 | 07:46 PM
Bersaglieri's Avatar
Do you know any real mechanics? I mean ones who build motors or something, not the guy who changes oil at jiffy lube or pulls codes at the dealership. Have them come over and help you. There is no reasonable way to do this over the internet.
Biggest thing is adjusting the valves correctly, MOST people do them wrong.
Old Jan 13, 2014 | 09:26 PM
I know mechanics. Everything done to my cars i do. I dont know why i was having problems with this car. I got the rockers adjusted and it runs great now just thinking i may have an opti thats ready to go with it having almost 260k on it im not bitching about it letting go now
Old Jan 17, 2014 | 02:35 PM
well i got it fixed, i was hanging a valve open by having the rocker too tight, and i had very weak spark, so a rebuilt at home opti and a little bit of valve adjustment and its running great, now i just have to adjust my clacking rocker (s)
Old Jan 18, 2014 | 02:41 PM
Chimera96's Avatar
read this for valve adjust with motor off
only thing is when there is no more "up/down" movement in PR that is zero lash
http://www.compcams.com/Instructions/Files/151.pdf
chuyz28
Feb 19, 2015 12:50 AM
InfernalVortex
Jan 17, 2015 09:35 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
