Cam surge with 847?
Old Aug 28, 2004 | 09:28 PM
brain's Avatar
Cam surge with 847?
How bad of cam surge do you guys have with this cam? Mine seems to be a bit excessive. I have 4.11s and the 847 on stock heads. Car pulls insane, but it still doesn't want to cruise at any rpm really. I have a tune from madz28 as well. I wonder if I have a burnt wire or something. When there is a small load on the engine, the "miss" goes away. But when cruising, it wants to "hesitate" or buck lightly. Any ideas? One last thing - I have a bad 02 sensor, and once the check engine light comes on, it quits bucking on cruise.
Old Aug 28, 2004 | 11:22 PM
GhostZ's Avatar
Re: Cam surge with 847?
Might want to get everything else fixed and then see if it still surges. GTP-6 with p&p'd heads and intake, A4, 3.73's....not excessive IMO.
Old Feb 10, 2005 | 04:54 PM
med_reject's Avatar
most likely due to your o2 sensor. When the ligh comes on, the pcm switches to open loop.
Old Feb 10, 2005 | 05:24 PM
brain's Avatar
Holy old thread batman! Thanks for the tip though! It was indeed the o2 sensor. No cam surge at all from 1300 on up.
Noenav
Mar 1, 2019 07:38 AM
AdsoYo
May 2, 2018 03:21 AM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
