View Poll Results: Keep it?
Keep it
83.33%
Go bigger!
16.67%
Voters: 6. You may not vote on this poll
Cam selection question (keep it or dump it)
Hey guys. I had a question on my cam. I'm going through the install now but it's still going to be a few weeks until I have money for a new opti and a few little things, so I've been rethinking my cam selection.
The setup on the car is:
Stock bottom end LT1
Lloyd Elliot Stage 2 LT1 heads
Long Tubes
Ported Intake
58mm TB
4.10 gears
Spec 4 clutch
Etc..
My area of concern is this:
The cam I bought second hand, it's a custom grind that was designed to be used with the stock bottom end. The previous owner said it was supposed to be shifted at 6300 (which is what I wanted for my bottom end). The specs are 224/230 .595/.595 108 lsa. I'm thinking this might be a little small and I might be able to get a little more power while staying within my limit of the stock bottom end.
What do you think?
Long Tubes
Ported Intake
58mm TB
4.10 gears
Spec 4 clutch
Etc..
What do you think?
I'd give it a try. Mine is smaller than that and the shift points are 6400 1st to 2nd, and 6300 to 3rd gear. 222/226 mid .5xx lift on a 112. Yours sounds interesting and would like to see the results when your finished.
that should be a hellofa cam!!! I would stick with it, and I hope those numbers are on 1.6's, because you could always go to 1.52's to drop it down a bit. If its anything like some other cams I have read about, it should drive really well, have good mid range, and be a monster up top. all around, ideal.
My goal for the project is 120, even if I have to lighten the car.
Jan 23, 2015 01:13 PM
NewsBot
Jan 23, 2015 01:10 PM
Dec 17, 2014 11:00 AM
