Cam - SC - LE3? Help me decide ?
97 A4, 130K. Jet Hot LT w/ true dual's, couple of bolt-ons.
Not sure how to spend me tax refund? Maybe $1500-2200?
Thinking of a GM847 cam with 1.7RR and all the other crap that goes with it.
OR LE3 Heads/Cam and not sure what else goes with it???
I might want to add a SC, just a small one. But it would be after engine work.
SO??? Where am I going to get the most HP for least cost?
Re: Cam - SC - LE3? Help me decide ?
Originally Posted by simple
keep saving
its gonna cost more then your refund to get all the right parts that will need upgraded
boost kills LT1's
boost kills LT1's
Originally Posted by 1racerdude
Do the LE cam and heads,and ask him for his setup for stock compression.
She won't last long with boost, of any PSI.
And save for a rebuild later or do it during the head-cam install.
New set rod bolts,rod resize(if you don't have PP rods),check crank,forged pistons,rings & brgs and oil pump.Boil block,hone,check everything and new cam brgs.
A blower is the biggest bang for the buck----but you have to have a fairly strong bottom end and the starter kit for 10PSI is over $2500.00 not including the engine.
I think you could get decient heads and cam for your 2000 and another 2000 for the "get by" rebuild that will go a long time maybe 40-50,000 miles with no breakage and the right choice of rings and brgs.
stock bottom end, dont sweat it. just keep the install clean and pay attention to detail
my point was that you will spend $1800 on a head and cam package but there are many other things you should/will need too upgrade as well
timing set, rockers, lifters, injectors, tuning($$$), converter or clutch, 12bolt if M6, gaskets, bolt set.... etc. etc.
i agree tho, i would do the LE stuff
but 1st i would keep saving and make a list and budget for parts that you will need along the way
OK OK - The price now goes up to $4K. Sounds like I can get all the CAM and Head stuff (1.7rr, gaskets, bolts etc) and the LT for sure.
Maybe I skip the SC and do a 100 shot?
stick with either 1.5 or 1.6 rockers
alot less valvetrain ear with them and lift should come from the cam anyway not the rocker ratio
no need for 1.7's especially with an aftermarket cam
Lt1son
Dec 31, 2014 01:35 PM
