cam removal
Old Jun 30, 2010 | 10:01 PM
camz28ryan's Avatar
cam removal
1996 camaro LT1. Replacing the cam and a few others. I've got the intake off, valve covers off, lifters/push rods and rockers. timing chain and cover off and i'm ready to pull the cam, I think. I've never pulled a cam but I thought it would slide out fairly easy. It appears to be stuck on something. Is there a certain way to pull the cam? I've bolted on the cam gear so I can hold on to someting and pulled and turned counter clockwise while putting pressure but no luck. I dont want to over do it and damage something. Advice would be appreciated.
Old Jun 30, 2010 | 10:20 PM
rclearyiii's Avatar
Have you unbolted the oil pump drive and removed it?
Old Jun 30, 2010 | 10:33 PM
camz28ryan's Avatar
Is that the bolt and tube on the passenger side by the fire wall that runs down through the valley?
Old Jun 30, 2010 | 10:37 PM
brucer's Avatar
unbolt and remove the oilpump drive. its in the lifter valley at the rear of the block..
Old Jun 30, 2010 | 10:41 PM
camz28ryan's Avatar
I unbolted it and the cam is still tight.
Old Jun 30, 2010 | 10:43 PM
camz28ryan's Avatar
I also remove the oil pump shaft/gear drive.
Old Jun 30, 2010 | 11:17 PM
RamAir95TA's Avatar
Did you assemble a make-shift handle out of 3 bolts to give yourself some leverage to pull? It takes a bit of force to dislodge the cam.
Old Jul 1, 2010 | 12:53 PM
seawolf06's Avatar
Be careful not to drop it or drag it on the bearings either. It will take some force to pull it out.
Old Jul 1, 2010 | 05:03 PM
cnorton's Avatar
Did you remove the cam retainer plate that bolts to the block behind the timing gear? It is held on with two Torx-head cap screws. You'll know if you took it off because normal Allen wrenches won't work. You need a Torx socket to remove the cap screws. The cam will turn freely but NOT come out until that plate is removed.
c
Old Jul 1, 2010 | 05:35 PM
camz28ryan's Avatar
Cool
Got the cam out and in. Thanks for everybody's input.
canbaufo
May 25, 2015 12:01 PM
StansZ28
Feb 19, 2015 07:39 AM
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
