cam questions
i am lookin into camming my car. I want something streetable so i was wondering if anyone knew how comp cams 305 cam (220/230 .510/.510 114 ls) compares to their 224/230 .503/.510 112 ls. which one is more streetable and how much tuning and other parts will i need for one of these. Also will LT4 valve springs work with one of these cams and 1.6 rr. Will i have enough valve-piston clearance.
Re: cam questions
Looks like you'll be up to .544 lift on those cams with 1.6 rockers which is more than what's allowable with the HOTcam springs.
I'd get the 224/230. Just start browsing through the supporting advertisers on this site, most of them have cam packages you can buy that has all the parts you'll need. As far as tuning goes, you can get a mail order tune from madwolf or PCMforless, no big deal.
Re: cam questions
Do not drive it on 30lbs injectors with a stock tune, it will run rich enough to do damage in that short amount of time. Could talk to the shop about getting there a couple hours early letting it cool off and swapping the 30s in there. There are worse ways to spens an afternoon than watching cars on a dyno.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
