cam question for the guru's?
Old Apr 2, 2008 | 04:40 PM
Billet ss's Avatar
I have two cams:
236/240
600/600
107lsa
236/242
580/585
111lsa
my question is which will make more power?
Old Apr 2, 2008 | 04:42 PM
dangalla's Avatar
heads, CI, intake, peak power i assume?
i think the first one will make more power, but a little higher in the rpm range
edit:i am not a guru
ulakovic22's Avatar
the top one
Old Apr 2, 2008 | 04:53 PM
Billet ss's Avatar
Why would you say the first one?
Old Apr 2, 2008 | 04:54 PM
dangalla's Avatar
more duration, more lift, and less seperation
Old Apr 2, 2008 | 06:38 PM
Billet ss's Avatar
How much more power?
Old Apr 2, 2008 | 06:41 PM
mdacton's Avatar
hardly none, nothing noticable anyway......but it would run crappier.
Is it a street car or what.....There is alot more to it than that.
I am a cam guru.....( I'm full of crap too!)
Old Apr 2, 2008 | 06:42 PM
git_sum's Avatar
I'd say the first one as well, might make the power a little sooner and give up a little quicker but i'd def. say it'll make a little more. Maybe 5, maybe 10, maybe more. Depends on the rest of your setup and what kind of lobes both cams are ground on.
Old Apr 2, 2008 | 07:35 PM
dangalla's Avatar
Originally Posted by git_sum
, might make the power a little sooner and give up a little quicker .
so more duration, more lift, and less lobe seperation is gonna make the power sooner?
Old Apr 2, 2008 | 07:36 PM
mdacton's Avatar
Might b/c he never said what it was going in or anything else.....
fartin in the breeze
Old Apr 2, 2008 | 08:00 PM
White96Z28's Avatar
I would also say it depends on your heads and exactly how aggresive those lobes are. I'm assuming the bottom one is using comp profiles, but I'm not sure about the top.
Old Apr 2, 2008 | 08:33 PM
slammed98gmc's Avatar
the first one is a custom ground cam for a 383 with trick flow heads
Old Apr 2, 2008 | 10:15 PM
git_sum's Avatar
I dont' see how it has more duration. But being that it's on a 107 it's going to want to make a little more down low but give up a little up top compared to the other cam i would imagine. Or that's usually how things work...
Old Apr 2, 2008 | 10:24 PM
dangalla's Avatar
cool, i was just asking. i just figured because it had a little more on the exhaust side and a little more lift it would move the power band. i dont know much about cams and i was trying to learn something
Old Apr 2, 2008 | 10:52 PM
MachinistOne's Avatar
There's some mis-information floating around this thread....
