cam question
Old Jul 8, 2007 | 09:47 PM
killacam2400's Avatar
cam question
i got a pair of trickflows i was thinkin about gettin the xfi 467 cam and lifter package just wondering if i should go bigger or smaller
they say the springs are good till 600 so i was def lookin for at the xfi line
tryin to keep her somewhat mild mannered with a good lope and bite
Old Jul 9, 2007 | 07:52 AM
Revolutionary's Avatar
It's definitely going to have some lope with that cam. It will take advantage of those heads but you might need to do some tuning to get it right. I've used that on a bunch of 383's that run really well. Perfect size for a 383 street car but IMO about 5 degrees too big for a daily driven 350.
Old Jul 9, 2007 | 08:04 AM
96capricemgr's Avatar
Trickflow themselves says to reverve those heads for boost and strokers. They will drop compression on a stock shortblock which is the wrong way to go for NA use.
The XFI grinds are designed specifically to take advantage of the capabilities of beehive springs so expect valve control issues if you try to use the springs that cmae in the Trickflows.
There is more to springs than seat pressure and lift capacity.
I would agree that cam is too big and go a step further and challenge you to find examples of the XFI gronds actually performing.
Old Jul 9, 2007 | 01:59 PM
so what cam would you recommend? a 503? and should i really keep those valve springs or change em out?
Old Jul 9, 2007 | 02:06 PM
Honestly I would shelve those heads till you can do a shortblock to compliment them. Lowering compression while trying to do a cam is the wrong way to go.
More duration will generally hurts lowend, compression helps get it back.
The 503 is a decent cam but even with that I would rather see someone increase compression rather than drop it.
You can get the heads heavily milled and then deal with intake mating but IMO not worth the hassle.
Old Jul 9, 2007 | 02:10 PM
reamo04's Avatar
or get the block zero-decked, that would help out too
Old Jul 9, 2007 | 02:18 PM
they make a shaved version of the trickflows with smaller combustion chambers like 55cc instead of 62cc but someone told me they bump you past 11.1 so no 93 pump gas. last month i found a good deal on ported 62cc trickflows so i picked em up
Ive seen a few ppl run the 62cc trickflows and had stock bottom ends thats why i need sum clarification before i buy this cam and the rest of the parts
Old Jul 9, 2007 | 02:25 PM
SStrokerAce's Avatar
It's a LT1 don't worry about the high compression it can handle it without a problem. I typically help out guys running 12:1 383's.
Bret
Old Jul 9, 2007 | 02:31 PM
well my heads are the 62cc version sooo is there no way they will work na on a 350?
Old Jul 9, 2007 | 02:47 PM
reamo04's Avatar
you can get the heads milled down, or the block zero decked, either one will help.
Old Jul 9, 2007 | 02:58 PM
stock cc is wat 54 and the trickflows are 62 so if i got them milled down how much would they have to get milled to while still gettin the most out of them ?
and is milling the heads smart or should i just save and stroke her to 383 396 or turbo or sumtin ?
Old Jul 10, 2007 | 07:42 PM
You really can't mill them that much. If you start really milling something you have to do the same to the intake manifold and then you will have to check pushrods as well.
Bret
Old Jul 10, 2007 | 07:48 PM
I am running 11.2-3:1 on 93 octane without a problem, lots of guys do.
Cranking compression is 225-230psi . I remember when I thought magazines had decent info and on gen 1 builds they claimed 180-190psi cranking was the max on 93 octane. The LT1 breaks a lot of the old rules, not just the reverse flow cooling but the injection that makes it possible to run compression like this.
Old Jul 10, 2007 | 08:13 PM
Dwayne, those play into it but the LT intake is one of the big reasons why they can run stupid compression. When you don't fill the cylinder well you can compress the **** out if it!
Old Jul 10, 2007 | 10:12 PM
maro z28's Avatar
What is it exactly about the stock LT intake that causes a lack of cylinder fill? Can this be corrected by porting the heads or intake or even with a bigger cam?
