Cam positioning and Optispark?
Old Dec 2, 2008 | 06:21 PM
Airbornec507's Avatar
Arrow Cam positioning and Optispark?
I'm just curious as to what could have caused my first 3 opti's to destroy themselves internaly. I'm running the delteq system now and everything runs fine for the most part accept for random misses at times. Cam dowl pin length is fine.
Here's what I am thinking could be causing it.
112 LSA installed on a 109 centerline instead of the recommended 108 thus 3 degrees advanced.
So question is could the cam being set up like this cause the opti to be out of position for the spark events?
Just some random data that may or may not influence your response:
DCR 8.4
SCR 11.3
Heads milled 50cc's
1995 OBDI
I was thinking of eventually picking up a dynaspark but if the cam is degreed weird then a better opti realy isn't going to help any. Maybee the cam position has nothing to do with it I don't know. That's why I'm asking. Thanks!
Old Dec 2, 2008 | 07:07 PM
Stl94LT1's Avatar
Cam degreeing shouldn't have any different effect on the opti. Are you sure the camshaft dowel pin is the correct length?
Old Dec 2, 2008 | 07:10 PM
Yep, it's the most common cause of repeated opti destruction.
Old Dec 2, 2008 | 07:14 PM
If .650" is correct then yes. I did have to grind it down some.
Old Dec 2, 2008 | 07:25 PM
Stl94LT1's Avatar
Copied from "shoebox" site.
GM specs indicate that the dowel should be .620" long (protrusion from the front face of the cam) for the vented optispark. Some people have said it is supposed to be .685". Mine was actually .650" and still was in no danger of bottoming out in the optispark drive (I'm thinking .685" might be the max it could be).
Old Dec 2, 2008 | 08:14 PM
HottestZ28's Avatar
not to hi jack but when you order a cam and it says 92-97 LT1 what exaclty do you need to do in order to get correct dowel pin length?
Looking into CC503 or CC306
Old Dec 2, 2008 | 08:24 PM
marshall93z's Avatar
I cut/ground mine down to the right length.
Old Dec 2, 2008 | 09:49 PM
It would not hurt to double check the pin to opti clearance with some clay.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
