cam install - now car won't start
Old Feb 27, 2004 | 07:02 PM
94TA_LT1's Avatar
Hey hope one of you all has an idea. I installed a hot cam in a friends 96 z28 and now the car won't start. It tries to fire but seems to be out of timing. I also removed the air and egr if that makes a difference. I also checked the sparkplug routing and have new sparkplugs in it. I went back and double checked the opti spark. Any ideas? Does it matter if the rear O2s are unplugged or if the cam was originally for a 94 and we switched the pin
Old Feb 27, 2004 | 07:04 PM
Jason Dove's Avatar
Either the pin is to long/short and/or the Opti is not seated correctly.
Old Feb 27, 2004 | 07:06 PM
94TA_LT1's Avatar
the pin is right and the opti fits on fine. i even took the cover off the opti and looked at the rotor and it seems to be in the right place
Old Feb 27, 2004 | 07:17 PM
Frans96SS's Avatar
i just did an opti in my car last night... i thought the pin was in also about 10 times but my car wouldnt start also but when i finally got it right it went right in a fired right up
Old Feb 27, 2004 | 07:24 PM
94TA_LT1's Avatar
how can you put it on wrong. the pin only fits in one hole on this cars opti
Old Feb 27, 2004 | 07:29 PM
94TA_LT1's Avatar
Old Feb 27, 2004 | 08:08 PM
94TA_LT1's Avatar
any more ideas?
Old Feb 27, 2004 | 09:15 PM
rocmemphis's Avatar
Not to sound stupid or anything but did you make sure you put the coil wire back on? I was in such a hurry at the end of my install that I forgot
Old Feb 28, 2004 | 08:39 AM
94TA_LT1's Avatar
i got that on
Old Feb 28, 2004 | 09:31 AM
faded93bird's Avatar
Try reajusting your rockers, they may be too tight.
Old Feb 28, 2004 | 10:54 AM
94TA_LT1's Avatar
i redid them and it did not change anything. thanks for all the ideas guys
Old Feb 28, 2004 | 11:04 AM
RMC's Avatar
RMC
Too tight rockers is a very very common error, the books are all sort of ambiguous... symptoms of rockers too tight would be:
The engine will be firing but may not start.
You'll hear the cylinders firing but it will sound like it's blowing out the exhuast/and or back into the intake which might make it seem like the timing is off.
If you get it running it will backfire and pop.
EDIT: dohh.. you snuck that reply in before me. How did you re-adjusted the rockers? What are the steps you are doing.
aintno6's Avatar
did you check for spark?
Old Feb 28, 2004 | 06:27 PM
94TA_LT1's Avatar
it has spark. to adjust the rockers i backed them all off and then let them set for awhile. Then i did them in the order the book said, taking them to zero lash and then going an extra half turn. Is that right? Would it matter that i put 1.7 rockers on? Does that change anything?
Old Feb 28, 2004 | 08:14 PM
try just going to zero lash and see if it dose anything even a 1/16 of a turn can make a difference. It took a few time to get mine right and i had only one that was off and the car wouldnt idle right.
