cam hitting rods......
Old Nov 15, 2007 | 08:13 AM
  #16
cehan's Avatar
Originally Posted by thebufenator
I just installed my cam into my 383 shortblock, and the lobes are hitting the rods.......
does this mean the cam is too big?
You do have the timing chain set installed, right? The small base circle cam in my 383 would come in contact with the rods before I installed the timing set.
Old Nov 15, 2007 | 08:53 AM
  #17
thebufenator's Avatar
Yeah, I have the timing set installed......
Its weird, the cam is a used LE4 cam for a 383..........
maybe I need to check the timing....
Old Nov 15, 2007 | 08:57 AM
  #18
sleepyTA's Avatar
I have the cc306 cam(standard base circle) in my 383 with no interference problems.
Old Nov 15, 2007 | 09:06 AM
  #19
Z-RATED94's Avatar
Just because it worked with someone elses rotating assembly doesn't mean it will work with the parts (rods) you have.
Old Nov 15, 2007 | 11:51 AM
  #20
Masnart39's Avatar
1, 2, 5, & 6 will hit, and you can use a long wire tie to check clearance. They are about .060" thick
Old Nov 15, 2007 | 02:05 PM
  #21
2QUIK6's Avatar
what exaclty is a small base circle cam?
how does it differ?
Here's a pic for reference, top cam is a small base circle LPE 211/219 cam.
Middle cam is a LE1.5 cam, about a 1" base circle.
Bottom cam is the stocker, about 1.2" base circle.
The idea with most cams to to make the max lift on the lobe just a tad shorter than the cam bearing surface, so the lift determines what the base circle will be.
Old Nov 15, 2007 | 03:57 PM
  #22
WS Sick's Avatar
I would just clearance the rod bolts at this point, no need to go buy a new cam, its easy and you will have no problems if you remove only whats needed.
Old Nov 15, 2007 | 04:10 PM
  #23
Whats the normal procedure? Just pull each of the rods out and grind with a dremel one at a time?
Old Nov 15, 2007 | 06:26 PM
  #24
Okay, I just pulled the cam and its "base" is exactly 1"
I know 7/8 is hitting, but cant figure out which one.
and then it looks like 1/2 is, not sure which.
Old Nov 15, 2007 | 06:28 PM
  #25
mdacton's Avatar
put some clay on it.....put a little oil on top of the clay so it wont stick on the cam, rotate it and see whats hitting.
What rod bolts are you using?
Old Nov 15, 2007 | 07:04 PM
  #26
okay, need to get clay......
I am using ARP rod bolts
is there anything else I need to do other then remove the rod and grind the head of the bolt?
any changes after re-installing the rod?
Old Nov 15, 2007 | 07:06 PM
  #27
mdacton's Avatar
you have to make sure it will even work first. Just do a little at a time and try it at least. Take the rings off so you don't break one...you will have it in and out several times
NewsBot
Mar 13, 2015 07:15 AM
armedtrigger
Feb 24, 2015 08:30 PM
mark0006
Feb 3, 2015 05:12 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
