cam hitting rods......
Old Nov 14, 2007 | 09:40 PM
thebufenator's Avatar
I just installed my cam into my 383 shortblock, and the lobes are hitting the rods.......
does this mean the cam is too big?
what are my options?
I am new to this.....
Old Nov 14, 2007 | 09:43 PM
Stl94LT1's Avatar
You need a small base-circle camshaft to work with your rotating assembly.
Old Nov 14, 2007 | 09:44 PM
mdacton's Avatar
what rods?
sometimes you can grind the rod a little. If not then go to the small base cam
Old Nov 14, 2007 | 09:46 PM
I am using the stock 5.7" rods....it seems to be tapping where the rod bolt is
Old Nov 14, 2007 | 09:47 PM
mdacton's Avatar
how much....try to grind the top of the bolt a little at a time, it may work it may not
Old Nov 14, 2007 | 09:58 PM
1racerdude's Avatar
Old Nov 14, 2007 | 09:59 PM
it may only be one rod bolt.......I'll have to check.....
Old Nov 14, 2007 | 10:06 PM
1racerdude's Avatar
They usually hit on more than one rod.
Do a Google I think 2-7 are 2 of them.
Old Nov 14, 2007 | 10:14 PM
what exaclty is a small base circle cam?
how does it differ?
Old Nov 14, 2007 | 10:43 PM
1racerdude's Avatar
The cam is physically smaller. This gives the rods enough room to swing.
A .900-.950 base circle should be plenty.
Old Nov 14, 2007 | 10:45 PM
wont that effect the geometry of the valvetrain?
Old Nov 14, 2007 | 10:56 PM
1racerdude's Avatar
NO/yes
Spects are the same on the cam, Ya will have to get longer push rods which ya probably were going to need some new ones anyway.
Old Nov 14, 2007 | 11:43 PM
Wild1's Avatar
Silly question. Did you double check your cam timing during the install?
Old Nov 14, 2007 | 11:48 PM
1racerdude's Avatar
Doesent matter.
383+standard base cam = crash.
Old Nov 15, 2007 | 07:52 AM
RicocheT's Avatar
this will work
i think it hits on 2 4 5 and 7 ... But you should check all to be sure. Doesn't take much grinding for it to clear. make sure you have about .050 clearance.
