Cam guys: pls post your gas mileage!!
Originally posted by ACA Performance
dude 8mpg is hella bad. something is out of whack. you have a 383 with not too big of a cam. people with bigger cams get more than that.
I have a 383 with a XE 230/236 on a 110LSA and get around 15-16MPG with primarily city driving. I haven't taken any long trips yet with this motor so I don't know about highway miles.
i had a 69 camaro with 383, 244/256@.050, .555/.572 lift & 108lsa. Turbo 350(built) with a 3600 holeshot converter and 4.10's. had 275/50/15 dr's on the back and driving it everyday i was getting a little over 10mpg in the city. oh and it had a vic jr. intake and 750dp with an 850 baseplate that had been worked over a little. if you dont get any better mileage than this with a fuel injected car and better gear ratios then you are just driving the sh!^ out of your car or something is seriously wrong.
Originally posted by philcam01
ACA performace
Why would you say that??? Running 110 octane and 12.7 comp with 3.73's . Just trying to understand why you would think that.
ACA performace
some of these numbers are downright frightening me, others not so much. i have a nitrous cam waiting to go in that is fairly aggressive and i was hoping to not lose too much in the mileage arena. i currently with a missing opti and all the bolt ons am getting in the neighborhood of 325 to a tank (300-350 depending on what i drive). im hoping to stay in the 250-275 range with the cam. however, i do drive her really easy.........maybe most of you guys have leadfeet
brian
brian
brian
brian
Originally posted by D James
What cam are you going with, I myself am waiting for my 224/236 536/555 114 cam to arrive
XTREME Comp Cams 230XH Camshaft, 230/242 duration @ .050", .510"/.540" lift with 1.5 rockers, .544"/.576" lift with 1.6 rockers. 114 LSA
thats the cam im running, ill be running the 1.6 rr's. i will be running an NX wet shot, not sure how much though. id like to see where i stand NA before i install it. ill have stock heads also. maybe ill stick with the 1.5 rr's for now.....
Brian
