cam dowel pin length??? do i need to trim??
Old May 7, 2010 | 04:10 PM
z28beast's Avatar
i have a cc305 i installed into my camaro....i didn't trim the pin at all... and when i installed the cam gear i used new arp bolts and the heads of the bolts stick off the gear about as far as the pin does...is this bad?
Old May 7, 2010 | 04:13 PM
RamAir95TA's Avatar
Depends on how long the pin is and what type of optispark you're installing. If you're converting to a vented optispark, the pin needs to be around .630" long. If you have an unvented opti, you can either remove the pin altogether, or trim it to .300".
Old May 7, 2010 | 08:20 PM
bw_hunter's Avatar
Don't remove the pin, it locates the cam. Your stock 94 distributor was driven by a splined central shaft and the pin had no drive function. Sticking out as far as the bolts doesn't matter.
Later distributors were driven by the pin and the length matters...they are about 5/8" from the cam face....
Old May 8, 2010 | 10:10 AM
Stl94LT1's Avatar
As long as the pin isn't making contact with the timing cover you are allright.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
chuyz28
Feb 19, 2015 12:50 AM
