Cam centerline
Old Dec 22, 2005 | 08:53 AM
JCsZ28's Avatar
Cam centerline
I am used to the old motors where the cams are measured on a 110 degree centerline and I am hearing the LT1 is on a 117 degree. Is this true and if so, what is the difference? How does the 117 compare to the 110?
Old Dec 23, 2005 | 10:41 AM
MyShibbyZ28's Avatar
Re: Cam centerline
Smaller LSA's (Lobe Seperation Angle) tend to make power a lot faster in the RPM range than higher LSA's do. The idle also gets changed, and becomes more choppy. If you wanted to compare power produced; 117* and 110* with the same lift and duration would most likely make around the same power, but the 110 would do it faster and make the power last longer to higher RPMs.
rideordie
Nov 5, 2019 04:52 PM
RUENUF
May 25, 2016 08:10 PM
Fastbird93
Apr 9, 2016 07:01 PM
RUENUF
Mar 13, 2016 03:39 PM
bowtieboy95
Jul 1, 2015 06:49 AM
