cam bearings
Old Nov 14, 2005 | 07:11 PM
blazzinbird's Avatar
cam bearings
is it better to have a shop put in new cam bearings?
also how much do they cost?
i just got a 94 formy and it had lost oil pressure, he replaced the oil pump, and said there still was no pressure so im thinking cam bearings
Old Nov 14, 2005 | 08:03 PM
Janny's Avatar
Re: cam bearings
I'm wondering if anyone has ever done these without pulling the engine, so maybe we'll both get an answer here.
Old Nov 14, 2005 | 08:24 PM
Re: cam bearings
The engine has to be removed o change bearings, cause you wont be able to get the rear one!
Old Nov 14, 2005 | 08:26 PM
marktisch's Avatar
Re: cam bearings
Have a shop put them in, it requires cam bearing install tool. They can be bought from summit or something if you really want. You should have a shop do it for you, it's not to expensive and you know it will be good. I have never heard of anyone doing cam bearings in the car but could be wrong.
Old Nov 14, 2005 | 09:34 PM
NeverEverSatisfied's Avatar
Re: cam bearings
[QUOTE=marktisch]You should have a shop do it for you, it's not to expensive and you know it will be good.QUOTE]
LOL yeah ok, so you are telling me any shop is going to do it right? I highly doubt it when you got a kid that barely knows where his turn singnal fluid is on his car changing your cam bearings you might wanna watch out.
Old Nov 14, 2005 | 09:39 PM
rskrause's Avatar
Moderator
Re: cam bearings
It's kind of tricky and as mentioned, you need a special tool that is useful just for this one job. It would be difficult to do in a 4th gen with the motor in. For sure you'd need to strip everything off the front of the motor and remove the radiator. And getting the old bearings out is another story. Remember - the whole job has to be clean, cleaner, cleanest.
Rich
Old Nov 15, 2005 | 02:15 PM
Janny's Avatar
Re: cam bearings
Thaks for the info guys. I was kind of afraid it couldn't be done in car. I'd never heard of anyone doing it.
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
