which cam?
which cam?
I am getting my intake pulled to fix the rear seal. i was told that if i had a cam to put in it, this would be the best time to do it. i have done some looking around and ive been seeing the cc306, cc305 and the lt4 hot cam what would be the best cam to use seeing as i still have the stock valve train. i plan on doing more to the valve train as soon as funds are up a little higher. thanks for your opinion.
Re: which cam?
Save your money and do the cam swap when you have the $ for the supporting parts. As for which cam you should get is like asking what shirt you should wear. Do some research and find one that suits your driving needs and meets your performance goals.
