calipers
Old Sep 1, 2003 | 09:47 AM
Like My Taillights?'s Avatar
calipers
how do you know when you need new calipers? My pads and rotors need replacing but I'm not sure if the calipers should be replaced as well?
Thanks, Rob
Old Sep 1, 2003 | 10:14 AM
OldSStroker's Avatar
Rarely would you need new calipers. If you have mega miles, you might consider rebuilding them with a GM kit. (Under $20), but if they aren't leaking, and replacing the pads and rotors, the wear parts) gives you back normal braking, you probably don't need rebuilt calipers.
You might consider changing/flushing the brake fluid during or after your pad and rotor change. Follow the service manual directions, bleeding the master cylinder first.
Henson071
Sep 18, 2015 04:01 PM
force10
Jul 30, 2015 04:56 PM
alphaauto
Jul 26, 2015 04:40 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
