A.c.&p/s Delete???
If you are deleting the AC and PS, there is nothing left for the belt to drive except the alternator. Instead of getting "delete" pullies, simply get (or make) the bracket to drop your alternator down below the engine, and use a simple belt (no tensioner) from the crank pulley to the alternator.
they do make an AC delete pulley, I just put one on my car. AS far as PS delete, I haven't seen a ready made pulley, but you could have one made pretty easy. Or you could low mount the laternato where the AC used to be and possibly kill multiple birds with one stone... There are pics of this setup floating around here somewhere
here's what you need: http://www.madmanandcoracing.com/lt1...orbracket.html
You will still be able to mount a SC, since it sits on the other side and uses different pulleys.
Steve10 also has what you need: http://www.mycamaroz28.homestead.com/
alex5366
Mar 8, 2015 11:32 AM
