a/c delete walkthrough please
Old Dec 13, 2010 | 09:20 AM
ryanzz28's Avatar
I need a walkthrough for doing an a/c delete on my '95 camaro z28. I know that i need to get the pulley from gm and will this set some codes ?
Old Dec 13, 2010 | 09:28 AM
RamAir95TA's Avatar
Re: a/c delete walkthrough please
It's easy...just remove everything and install the pulley. If you want to remove the evaporator core and airbox though, that's far more involved and requires removal of the dash. You won't set any codes if I remember right...
Old Dec 13, 2010 | 09:37 AM
Jlo's Avatar
Jlo
does the a/c really negate much HP? or is it just a weight issure?
Old Dec 13, 2010 | 09:44 AM
RamAir95TA's Avatar
It's a weight issue, not a HP issue. When the AC is off the condenser is just an idler pulley. But when the AC is ON of course it robs HP, and more notably, system voltage.
Old Dec 13, 2010 | 09:50 AM
Jlo's Avatar
Jlo
That's what I figured, I think I'll keep the A/C for now, but if it was a strip car I'll consider it..
Old Dec 13, 2010 | 10:58 AM
Procharged94Lt1's Avatar
There is also the benefit of less resricted air flow thru the radiator-
It will set a code in your PCM, but it won't set off the SES light.
Old Dec 13, 2010 | 11:17 AM
ryanzz28's Avatar
I'm just doing it too clean up the engine bay alittle bit, and getting rid of the weight is a plus. It's going to make it easier too when i go to have my headers installed. plus i'm bored it will make a quick winter project. I can't wait till this spring though, my car is going to be a beast after it comes out of the shop. I'm still saving up for a few things but this is what its going to have. LE1 cam and head package, i don't know exactly what cam yet. 3.73's most likely from gm cause i heard richmond and the other brands whine. my hooker super comp headers, ford redtop injectors, 3inch x pipe, 2 magnaflow cats, 2 flowmaster 10 series all the way to the bumper. egr air pump delete, pcmforless tune. new plugs,wires, optispark. thats about it. i already have a 2800 stall and a trans go hd2 shiftkit.
Old Dec 15, 2010 | 06:00 AM
Guest47904's Avatar
Guest
You can prevent the code pretty easy
With a simple voltage divider, you can prevent the code. Just put 2.5 volts on pin 12 of the Blue PCM connector with the red/black wire.
Old Dec 16, 2010 | 01:05 AM
ryanzz28's Avatar
Re: You can prevent the code pretty easy
it's ok I 'll be getting a pcm from pcmforless anyways
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
tnmotown
Aug 10, 2015 11:52 PM
MikeWhitener
Aug 2, 2015 06:17 PM
IgorT.455/406
3rd Gen / L98 Engine Tech
Jun 8, 2002 05:07 PM
