A/C Compressor (I've Searched)
Old Jul 30, 2003 | 02:09 AM
TransAM93's Avatar
Well my A/C has been going out for quite some time. It blows air fine, but it's enough to keep me alive, it's never "cold". The Texas heat is killing me, so I figured it's time to get it fixed. After doing some reasearch, I keep hearing about the A/C Clutch. It's obviously cheaper than a new compressor, so how can I test if it's this before taking the plunge? Whenever I turn the A/C on you can here the compressor start working (It's loud, sounds terrible.) It almost seems to shut off for short periods of time (judging by the fact the noise stops) and then kicks back on again. I can notice sloppy response and a lack of power when the A/C is on as well.
Assuming I need a new compressor (car has 81K miles), where's the cheapest place to buy one? I've heard ~$350, but no references to where.
Thanks in advance,
Nick~
Old Jul 30, 2003 | 02:20 AM
SVT Killer LV's Avatar
Try charging the system. If that doesn't do it, then put a new clutch on the compressor, check to see if it engages and disengages properly though.
Old Jul 30, 2003 | 03:37 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
sounds like either the evaperator, or orfice tube
fyi, if you wanna try a compressor, I have one for $65.
Old Jul 30, 2003 | 11:31 AM
TransAM93's Avatar
Thanks for the replies. Where can I buy the A/C Clutch alone, and what Part # do I need? Also, will I need to bleed the system before chaning the clutch, or only if changing the whole compressor?
One last question (at the risk of sounding like an idiot), can you give me a step by step of "charging the system"? I want to try doing this myself.
P.S> Jordan, you live in Coppell? I'll be getting a bike in the next few weeks (my first) we should go riding sometime. I graduated from CHS in '02, but your names not familiar.
magman
Apr 15, 2016 03:08 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
autoxr166
Sep 25, 2015 04:21 PM
Fatdog2
Sep 16, 2015 11:04 PM
Sep 11, 2015 09:44 AM
