A/C Compressor Clutch Slips
Old Apr 19, 2005 | 10:08 PM
trashtalk's Avatar
It appears that my compressor is locked up, but I wanted to ask if there was anything mechanical in the clutch that would cause it to lock up and not turn the compressor. I believe I still have proper line pressure as the clutch will try to engage when commanded, but it will not grab the pulley and turn -not even turn a little bit. It just slips. After a few seconds it disengages and will not reactivate. I then get code 67 (no change in line pressure after 10 secs) when this happens. I do not get a code 66 (pressure too low or high). Reset the PCM, and can repeat the whole process.
Is it possible for the compressor to lock up but still have a leak tight system? I'm guessing it is, unless the clutch has some kind of mechanical lock that activates when it is worn too much.
This is the original compressor/clutch. I'm at 189K now. Can't complain if it is time for a replacement. Any thoughts appreciated.
94 Z28 converted to M6 at 145K
Old Apr 20, 2005 | 02:53 AM
toadies101's Avatar
Re: A/C Compressor Clutch Slips
Could be a pressure switch gone bad... If you think you need a new A/C clutch I have one new AC Delco in the box... email me if you need it
sleeperZ96BT
Sep 9, 2015 08:28 AM
raroz28
Sep 8, 2015 06:10 AM
WPHIG2
Aug 27, 2015 06:37 AM
karpetcm
Aug 14, 2015 03:02 PM
Jul 17, 2015 02:47 PM
