A/C compressor bypass?
Old Jan 1, 2005 | 05:05 PM
fuzzyz28's Avatar
Question A/C compressor bypass?
My A/C compressor has failed. The car runs great, but it's making a horrible noise from the Compressor area and it doesn't blow cold air anymore.
In order to delay the expense...can I just run a shorter belt and bypass the compressor without harming anthing and wait 'till summer for the fix?
If so...what length belt do I need to bypass the compressor?
Thanks for any help.
Old Jan 1, 2005 | 05:08 PM
BadAssed93Z's Avatar
Re: A/C compressor bypass?
i could be wrong but i think you just need to run the 1LE belt. just go to your local auto parts store and tell them it was a non ac option car and they should have a part number for you.
Old Jan 1, 2005 | 06:15 PM
Lower's Avatar
You can not simply replace the belt. You'll need a 1LE a/c delete pulley (about $60 locally, about $35 online).
After removing the compressor, one puts this dummy pulley into that spot, and with a little luck the belt will still fit. I say a little luck becuase some experience a belt replacement is needed.
See here for more info:
http://web.camaross.com/forums/showthread.php?t=321589
Old Jan 1, 2005 | 06:39 PM
NOMAD's Avatar
Yep, gotta have the delete pulley. I usually build mine out of scrap aluminum and idler pulleys from 2.8 camaros
-Shannon
Old Jan 1, 2005 | 06:46 PM
fuzzyz28's Avatar
Ok...I'll just go ahead and replace the compressor...got to love car repairs.
magman
Apr 15, 2016 03:08 AM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
War Engine
Sep 18, 2015 07:28 PM
