A/C clutch diode
Old Aug 22, 2016 | 05:53 PM
Ryan Sandell's Avatar
A/C clutch diode
I had to replace the electrical connector to the A/C clutch on my 94 Trans Am, but there was not a diode between the two wires anywhere near the connector. One diagram I saw said it should be 16mm from the connector. At the top of the engine where the harness joins up with the fuel injector harness, there is a long epoxy filled tube hooked to the black wire, but I can't see the other end to see if the green wire goes into it. Did the location of the diode change over the years? The new connector with 12" pigtail does not have a diode.
Old Aug 22, 2016 | 10:55 PM
GaryDoug's Avatar
Prominent Member
Re: A/C clutch diode
Here is the diagram from the 94 service manual. You can get the whole manual using a link here: http://www.mediafire.com/download/v2...n_complete.pdf
Click on the image to make it clearer.
Attached Thumbnails A/C clutch diode-ac-diode-location.jpg
plattted
West South Central
Sep 7, 2015 02:45 PM
Anon
Jul 23, 2015 12:18 PM
browenb
Jul 19, 2015 04:14 PM
cboyer45
Parts Wanted
9
Jun 17, 2015 10:51 AM
Chet1185
May 10, 2015 09:24 AM
