C-5 rim fitment question
Old Feb 28, 2004 | 08:29 PM
1msfyter's Avatar
18x9's will they fit on the rear? The guy who has them said they are from a 97 or 98. SPacers???
http://www.rims-and-wheels.com/image.../aly05099u.jpg
Old Feb 28, 2004 | 09:12 PM
dkeers's Avatar
I put the stock rims and tires from a 2002 vette on my z28. They would rub on the inside when someone was in the backseat, or if I went around a corner hard. I did a little "clearancing" with a BFH and they have not touched since.
Dustin
Old Feb 28, 2004 | 09:58 PM
Z95m6's Avatar
Dustin
Ditto, my car would only rub going around a corner fast. I did the hammer mod and never a problem again.
Old Feb 28, 2004 | 10:36 PM
1msfyter's Avatar
Also what lugnuts are you using? Can I re use stock ones that use a lugnut screw on cap?? Or any better ideas?
Old Feb 28, 2004 | 10:53 PM
ledfootz28's Avatar
stock ones will work.im gonna be ordering a chrome and locking lug set from rksport.
Old Feb 29, 2004 | 01:35 PM
camarokid24's Avatar
when I got my 97 c5 wheels I had to sand down the innner hole that fits on the hub on the rears because it was a 1/16th too small. As well using the BFH for the inner wheel wells.
Old Feb 29, 2004 | 01:47 PM
Bersaglieri's Avatar
xxsaint69x had them on his 94 Z, i believe he had to use a hammer to make room in the rear but thats about it. GL with the rims man
PS got to talk to you on AIM sometime today.
-Dustin-
Old Feb 29, 2004 | 02:45 PM
Black_Z28's Avatar
They'll fit fine. But like the others have said, you may have to do a little bit of inner fender work. All car are a little different.
Also, those are Y2K wheels. The wheels that came on the 97-99 C5s are different from those.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
cmdeshon
Jan 4, 2015 11:15 AM
siguy
Nov 27, 2014 10:07 AM
