Buying a 1994 z28 tomorrow, what to look for
Old 07-07-2006, 10:10 PM
obaja's Avatar
Hey everybody im new to this forum and have been reading up but can't find info on what to look for when i buy this z28 tomorrow. I was looking for something like a buyers guide, what problems to look for when looking at this car.
Its a 1994 z28 6 speed with 75,000 miles on it and looks-wise is in pristine condition. What i need to know is what to look for in engine and drivetrain issues. It has the stock clutch on it, time to change? stuff like that im interested in.
Thanks in advance
Marshall
obaja is offline
Old 07-08-2006, 02:14 AM
Trannykiller's Avatar
Re: Buying a 1994 z28 tomorrow, what to look for
ummm
Water pump and opti. Run your finger under the water pump, It has a "weep hole" when the pump starts to go bad it starts to drip on the opti and kills it. Everything else should be like buying another used car does the steering pull do the breaks pulse ect. Let the car sit at idle for 5 min and see if it runs hot after driving it. If the car looks prestine it was probobly taken car of. And with only 75,000 being a 94 should make for a decent car.
Trannykiller is offline
Old 07-08-2006, 02:18 AM
MENEGRANDE's Avatar
how much $$$$$$$$$$$??
MENEGRANDE is offline
Old 07-08-2006, 04:34 AM
PGM95Z's Avatar
Just looking "pristine" doesn't mean a good car.. I bought a "pristine" looking 95 Z28 with 50k miles.... And then spun a bearing 2 weeks later, finding out that the car had sat dormant for 2 years..
Make sure you check the history on the car..
Good side: rebuild = 383
PGM95Z is offline
Old 07-08-2006, 11:55 AM
Jlo
Jlo's Avatar
That's true but at least you got one of the better camaro's the 95 with the vented opti, from what I've seen the 94's opti suck.
Jlo is offline
Old 07-08-2006, 12:13 PM
obaja's Avatar
Could i order the newer 95 opti and put it on my 94? i mean its the same block would it fit right? Doesnt vented mean that water from the water pump could get in?
obaja is offline
Old 07-08-2006, 09:32 PM
BLDun's Avatar
You could put it on the '94 but there are some changes you will have to make in the mounting process. More than just bolting it on! If you search here you will find some indepth info on all that is involved!
BLDun is offline
Old 07-08-2006, 10:23 PM
anaik's Avatar
Here's what is needed to change from non-vented to vented opti.
http://para.noid.org/~muttvette/opti.html
anaik is offline
Old 07-08-2006, 11:34 PM
obaja's Avatar
WOW!!! i bought the car and it is as i said "Pristine". A 70 year old guy owned it and wanted to sell it because he had 6 other cars. I got it for a steal at $5000. It was originally $5300 but the day we went to look at it he put a little scratch in the front bumper by backing into it with another car, so we got the scratch estimated at a body shop and they said $300 to get it fixed so the owner nocked off $300 of the price.
Anyways it shifts and runs and starts good everything up to par. I just have a few questions, i hear a slight clunk coming from the rear of the car, like one of the right or left bushings, cant tell where its coming from. Sound occurs when going over a bump or dip- Anyone know the problem i might have back there? bad bushings maybe.
Another question is that when sitting in traffic or letting the car idle the temperature gauge moves all the way up to just before the last white line, is this normal due to no ventilation on the front of these cars?
Thanks alot everyone.
Marshall
obaja is offline
Old 07-08-2006, 11:40 PM
blackztpi's Avatar
lol, wow. you just straight bought it even though it had problems? the temp thing...it shouldn't heat up at all because the fans should come on. check the fans for operation. if the fans work, check fluids. not a bad idea to switch to a 160 thermo.
blackztpi is offline
Old 07-08-2006, 11:42 PM
StephenDeli22's Avatar
That clunk you hear in the rear is more than likely the rear hatch rattling around. Its a normal 4th gen pet peeve, along with slow window motors and optisparks.
About the idling temperature, the stock computer is like that the way its cooling fans are setup. Mine used to be like that and then I got a MadZ28 tune and he reprogrammed my fans to kick on earlier and I never see my temp gauge get past 190*.
StephenDeli22 is offline
Old 07-08-2006, 11:53 PM
obaja's Avatar
Really? is that MadZ28 tune your talking about something like a hypertech programmer or is it the stock computer from the stealerships that is hooked up?
obaja is offline
Old 07-09-2006, 10:46 AM
Ion (the guy from MadZ28) makes custom tunes to your car. You fill out a build sheet and he whips up a tune for you. You can swap car computers or you can upload a tune through a laptop like I did. If you swap computers and do the core charge there will be no downtime. Its the same concept as the hypertech I guess but better. Hypertech has had people actually report losses! Hypertech can adjust your fans too, but it wont be as good (or nearly as cheap) as a MADZ28 tune. Ions tune deleted my skip shift, you will found out how bad that sux soon, and deleted my EGR/AIR. He also did power tuning which is a definite SOPT difference, even on a somewhat bolted on car like mine. Best 75$ I have ever spent on my car.
EDIT Ion's website is www.madz28.com and another computer programmer is www.PCMforless.com . Both are supporting vendors on this website.
Noenav
03-01-2019 07:38 AM
Cartercarterr10
Advanced Tech
01-15-2015 09:13 PM
cmdeshon
01-04-2015 11:15 AM
thenewkid
11-27-2014 09:41 AM
94z28jbw
09-08-2002 03:22 PM
Quick Reply: Buying a 1994 z28 tomorrow, what to look for
