Bushing help needed ASAP
Old Mar 27, 2004 | 04:11 PM
ismokerice's Avatar
I have been fighting a suspension build on my 94 Z28. I finally defeated the rust that had EVERYTHING welded together, everythings painted and ready to go back on. Now I'm Having trouble with the new bushings. I got a complete prothane kit and the directions for the front are missing. When I talked to the guy that I ordered the kit from he said I would have to remove all the metal parts for the front and reuse them. Do to the evil rust I was unable to remove the bushings intact so I bought new ones and removed all of the rubber(prothane suggested this when I called them). The front ones(horizontal) went in fine, no problems, but the rear(verticle) ones will not go into the metal shell. They look like they don't use the shell at all, the top is a big mushroom piece and the bottom looks like a cup and they look like you just press them into the control arm without the shell. Has anyone used this kit? Any help is greatly appreciated I need to get this done today!
Also on the rear control arms the kit comes with "thrust bushings" that are basically poly washers that go around the backside of the bushings. They don't want to fit but I think I can pound them in, if they are worth using.
Old Mar 27, 2004 | 05:48 PM
BamaZ28's Avatar
I am not to good with suspension, but my bro Formula03 is, send him a PM
Old Mar 28, 2004 | 12:27 AM
roadtrip120's Avatar
The vertical ones on the lower control arm, the outer shells have to go, the horizontal aouter shells stay.
make sure you use alot of poly lube, other wise they will make noise, i know mine do
Old Mar 28, 2004 | 01:08 PM
ismokerice's Avatar
Thats what I was thinking. The guy on the phone said I would have to reuse ALL metal parts. That would have saved me a day of burning/pounding and about $20 worth of new bushings that are now trash.
Old Mar 28, 2004 | 02:48 PM
Formula03's Avatar
Roadtrip120 is right the vertical ones should just press in.
Old Mar 31, 2004 | 01:36 AM
ismokerice's Avatar
Thanks alot guys! It's finally back together and off for alignment tomorrow. I'm just glad it's done, I think that was tougher than the header install, but it's done so I can check one more off the list.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jason Short
Jan 19, 2015 06:34 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
