Burnt another wire
Old Mar 26, 2004 | 01:30 PM
95Zdroptop's Avatar
Angry Burnt another wire
I went to start up the car today and it started missing. Well aparently a wire on the passanger side got to close to the belt and took a beaten. They where fine for a about 5 months. Is it better to take the alternator off and run them behind it to avoid the belts. Or is there any other way to do this. Also I might try the OVC wires again even though last time I messed them up and could not use them. Any input, instructions would be appreciated. And yes I have hooker longtubes.
Old Mar 26, 2004 | 03:35 PM
valter's Avatar
Mine previous setup inluded special wire hanger for 4 wires to sit tight in place near the belt. In process of installing 11mm thundervolts I had a hard time removing this hanger & even after this 4x11mm wires didn't fit there without touching belt. So I route two wires there (2 and 4 cyl) and 2 wires (6 and 8) over valve cover and then to another way to opti through a some free space on other side of alternator. Not a brilliant setup, but it's working fine.
grabbem88
20
Dec 27, 2015 07:42 PM
mattstrike
Mar 24, 2015 02:11 PM
jackpawt883
Feb 26, 2015 09:04 PM
jb4xx
Feb 2, 2015 10:00 PM
zman0069
Aug 2, 2002 02:09 AM
