Building Her Up
Old Oct 26, 2003 | 09:56 AM
AlmostfastLT1's Avatar
Building Her Up
If you guys didn't know motor is going to bite the dust, and that gave me a good reason to build a stroker motor. Could any of you guys give me suggestions on internals. Also, I am puting a better water pump and lower thermastat, but need to know if this will be cool enough for the summer with the stock radiator.
383
Cam?
Crank?
Valvetrain?
Rods?
Also want to use the stock heads to save money, but a friend it going to port and polish and the intake as well.
I apperciate the help to get me on the right track, Thanks Mark Tisdale.
Old Oct 26, 2003 | 09:02 PM
Anyone have any suggestions.
Old Oct 26, 2003 | 09:06 PM
RedPhenx's Avatar
you have emissions? daily driver? auto or manual? need more info before I start passing out worthless net tech info
edit: I see your sig now! doh, you have a manual.
Old Oct 27, 2003 | 09:33 AM
The car will be driven aleast 3 times a week. I am looking for 400rwhp on stock heads.
Old Oct 27, 2003 | 10:53 AM
WheelmanZ28's Avatar
Building a stroker motor with STOCK heads is like using an eyedropper when u need a firehose.
U mean ur not planning ANY head work at all? not even mild port work?
Old Oct 27, 2003 | 10:56 AM
Sweetred95ta's Avatar
He definitely said he was going to port and polish the stock heads.
Benji
Old Oct 27, 2003 | 11:09 AM
Yes i am going to port them very well. I am only keeping the block and the heads and maybe intake.
New everything
Old Oct 27, 2003 | 11:33 AM
S.J.S.'s Avatar
I just did mine and its sitting right here. Just remember...there is a lot of other things in there that need to be done and modified. I just got of the phone with Nu-Tek. Had my friend come up saturday and we were putting the motor together and realized the tock pan and windage tray will not clear. Another 400 bones down the tube for a Canton with shipping and oil pump and pick up. It's like a snowball.......just keeps getting bigger and bigger ($$$$$$$).
good luck.
Old Oct 27, 2003 | 01:01 PM
I hear that, all this work makes me want to make it just a 355.
Would It still be possible to make a crazy 355 to put out 400hp.
Old Oct 27, 2003 | 02:03 PM
It is definitely possible to make a crazy 355 with over 400hp. Gm847 and mildly ported stock heads makes around 400 at the wheels. Well I mean, there are other things you need, but a 400+ hp 355 is easily possible.
Benji
Old Oct 28, 2003 | 08:36 PM
Any suggestion on to what internals to use in the 355.
Old Oct 29, 2003 | 09:57 AM
ttt
Old Oct 30, 2003 | 10:54 AM
Anyone have any ideas on internals
Forged steel crank?
Forged steel rods?
Forged Aluminium piston SRP Keith Black etc?
etc?
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
