building 383 need help!
Old Jul 22, 2011 | 01:48 PM
camz28ryan's Avatar
my engine is off at the machine shop getting rebuilt, ive decided to do a 383 and want to know what i should do..
i was thinking the cam i should use is the cc503. is this a good choice?
car will be a daily driver, i have about $3,000 for the build, maybe more. im leaving the heads alone for right now just because i dont have the money for it.
i was thinking 383, cc503, hardened pushrods, not sure on rockers i have 1.52 comp cam rockers right now, will that be okay? new lifters, should i get a bigger tb? tell me what you would do, please i have to tell the guy what i want by monday, and its friday right now.. and input is appreciated!
Old Jul 22, 2011 | 02:07 PM
dennis5374's Avatar
Re: building 383 need help!
Build a 355. Ur gonna spend 1/3 of that too machine the block. Bore it 30 over use a federal mogul rebuild kit speed pro pistons. I love my xfi 280 cam but i have head work,1.6 rr and the beat of everything in my heads. If your building a 383 up ur budget too almost 3x what u have and do it right. Or just buy a shortblock from Golen engine service and call it a day.
Old Jul 22, 2011 | 02:14 PM
dennis5374's Avatar
Honestly i don't think you'll build either for 3k but especially not the 383. Block has too be clearenced and new crank will cost u half your budget. Reuse rods and crank. Have the crank ground and polished,rods resized. If u wanna gain power for cheap have them deck the block and mill the heads our motors can take alot of compression and 25 hp for every one point u raise the static compression. Have your machinist do a 3 angle valve job, open the throats up, clean the burring up, rough up the intake side too suspend fuel. You'd be surprised what you'll gain just from this.
Old Jul 22, 2011 | 02:15 PM
dennis5374's Avatar
I said 1/3 for the block but what i meant was block and crank
Old Jul 22, 2011 | 06:22 PM
RamAir95TA's Avatar
A 383 with stock heads and the CC503 would be a very disappointing combination, IMO.
A stock or close-to-stock rebuild is what you should be looking for reusing as many stock parts as possible, then put the added funds into the cylinder heads and valvetrain. Displacement doesn't make horsepower - a well-matched valvetrain and good tuning does.
What are your HP/ET goals?
Old Jul 22, 2011 | 06:37 PM
96capricemgr's Avatar
Even reusing untouched stock heads you can not do a decent 383 for $3000.
Why are you rebuilding it?
Old Jul 22, 2011 | 07:30 PM
dennis5374's Avatar
8k in my 355 with stock reworked heads
Old Jul 22, 2011 | 08:31 PM
dennis5374's Avatar
Not just motor but supporting mods also
Old Jul 23, 2011 | 12:08 AM
camz28ryan's Avatar
i was originally going to do a 355, but the guy that is doing my engine is a long time family friend, and said it would only be another 800 to do a 383 balanced and all. so i figured i would just do that. is having a 383 with stock heads bad? or just not worth it? and i will eventually do heads just not at the moment. and what kind of cam would be best for this build?
Old Jul 23, 2011 | 08:30 AM
RamAir95TA's Avatar
A 383 with stock heads and a cam would yield unimpressive results.
A 355 with ported heads/cam can yield over 400whp.
It pays dividends to wait until you have the fundage to do everything at once. Will your plan hurt? No, but having to do everything twice is less than ideal financially.
Old Jul 23, 2011 | 11:55 AM
camz28ryan's Avatar
okay, 400 rwhp is my goal. how can i reach that. i need ideas on cams that will be just right for me. and ive decided to not do the 383 and just put the money tht i was going to spend on that into my heads. so 355 here i come. haha
Old Jul 23, 2011 | 01:40 PM
RamAir95TA's Avatar
Here's how I would do it.
Stock crank, stock resized rods, a good budget forged piston, nothing fancy.
AI 200cc heads with a custom grind cam with all the fixings.
All the bolt-ons and a GOOD tune.
That's an easy 400whp. Most people overindulge on the rotating assembly/bottom end when it just isn't needed.
Old Jul 23, 2011 | 01:44 PM
grumpy Z's Avatar
Absolutely! I've used standard bore/stroke and stock pistons formy budget build. Focus on port/polishing the heads/intake and matching the right cam and tune. You might be surprised at how well it will run!
Old Jul 23, 2011 | 09:43 PM
camz28ryan's Avatar
thanks for all the input!! i will be on here asking questions about this build more than just this time!
Old Jul 23, 2011 | 09:45 PM
camz28ryan's Avatar
and what does AI 200 cc mean? and what do you mean by stock resized rods, where would i get them resized at?
