build list
Old Feb 25, 2007 | 12:17 PM
ScottZLT1's Avatar
build list
ok, does anyone have a list of stuff that ill need to complete an lt1 to lt4 convertion. I have the heads, and HOT cam and roller rockers and the new edelbrock intake is on its way. what are some of the other stuff that ill need to complete it. I have heard to buy 30lb SVO injectors. and i bought a flo-pro kit that has all the gaskets and i purchased the LT4 gasket off ebay new, but fuel pump? Tranmission upgrade? knock moduel? and who is the best for computer tuning? any advice would help before i break out the wrenches thanks
Old Feb 25, 2007 | 04:01 PM
2000GTP's Avatar
With the noiser 1.6 roller rockers, the LT4 knock module would be a good idea. As for the fuel pump, you shouldn't need a replacement unless your stocker is not up to spec. As for the transmission, I doubt the LT4 conversion will push the boundaries where you will blow your tranny. And for the tuning, a mail-order tune from Madz28 or PCMsforless should do the job.
pimpss96
Feb 12, 2015 01:28 PM
Jan 23, 2015 01:13 PM
