Brought Car Out Of Storage: Brakes are Rubbing??
Old Mar 24, 2003 | 04:39 PM
jpolz's Avatar
Exclamation Brought Car Out Of Storage: Brakes are Rubbing??
I brought my car out of storage for the spring and take it up to the gas station for a fresh fill up and a can of Seafoam in the tank. I noticed that my brake pads were rubbing while I was driving and when I hit the gas it sounded like sand paper. Did you top layer of my pads rust over or something? I'm assuming whatever it is will burn off after a few days of driving it around.
Or should pull out the C-Clamp and re-set the calipers??
Old Mar 24, 2003 | 05:15 PM
joeSS97's Avatar
More than likely just rust on the rotors,which will wear off.
Old Mar 24, 2003 | 09:38 PM
needmods's Avatar
I had what seems to be a similar problem with my car last year. After sitting in the garage for four months, my caliper slides developed a coating of rust and were sticking and causing wear to my rotors/pads
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
USAirman93
Nov 24, 2014 03:37 PM
