Broken throttle cable clip (pic inside).. how would it affect?
Old Jan 16, 2006 | 01:31 PM
Javier97Z28's Avatar
Moderator
Is this affecting anything, if so, how would the car react?
I temporarily tried to use some quicksteel on it until today when I order a new cable for it, but that broke off. Car seems to be OK..
Only thing that seems a bit off is my idle.. but I think that may be my IAC acting up, ran the car after my CSI install with no elbow on, may have sucked some crap into the iac.
Old Jan 16, 2006 | 01:33 PM
Stoopalini's Avatar
Re: Broken throttle cable clip (pic inside).. how would it affect?
Pics not working ....
Old Jan 16, 2006 | 01:34 PM
Moderator
sorry, wrong url
'94 Bad A Z28's Avatar
404 File not found...
Old Jan 16, 2006 | 01:35 PM
Stoopalini's Avatar
Ok, I can see it now.
My buddies '97 SS had the same thing happen. We cleaned up the surface and used some aircraft epoxy to fix it. Did this about 4 months ago and it's been fine ever since. You can get 15 min 2 part epoxy at any local hobby store (I happened to have some on hand from my airplane hobby).
Thomas.
LT1 Tech does display pics...
Old Jan 16, 2006 | 01:53 PM
Moderator
I know.. wrong URL.. fixed now
Yah, I'm not going to fix it, just replace it.. just curious as to what the effect of it would be.
Old Jan 16, 2006 | 02:11 PM
Stoopalini's Avatar
Poor throttle response ......... At least that's what happened with my buddies '97. The cable was flopping around not allowing the cable/sheath to function correctly.
Thomas.
Parts Wanted
Mar 17, 2015 11:24 PM
rjc1629
Jan 27, 2015 10:46 AM
edman
Jan 25, 2015 02:41 PM
Queens94z28
Dec 20, 2014 09:11 PM
omarECD
Aug 19, 2002 07:28 AM
