broken spring screwed up everything...
Old May 7, 2004 | 12:36 AM
fstenuf's Avatar
too make a long story short the valve dropped, when it came back up it got wedged in between the pushrod and the rocker arm. then the head of the valve came off and tore up the #7 piston then got sucked through and went to the #5 cylinder. tore up that piston too. well my mechanic said that he needs to get a complete bearing set adn a new oil pump so he's yanking the motor...any thoughts or inputs...or anyone else out there feel my pain? i'm gettin all new springs put on so hopefully it won't happen again for a long time. is there anything i can do to prevent this from happening again or is this a freak accident to mess up my 10k dollar motor?
Old May 7, 2004 | 09:47 AM
fstenuf's Avatar
ttt, any other horror stories like mine?
Old May 7, 2004 | 10:42 AM
Quick96Z's Avatar
i bent 4 pushrods on the dyno the other day. Luckily for me, the pushrods took all teh abuse. We did a compression and leak down test and everything is steady across all the cylinders. Hey, atleast you have an excuse for a 383 stroker
trav
Old May 7, 2004 | 10:46 AM
fstenuf's Avatar
Sorry man i already got a 396 stroker but what i don't understand is why just that spring broke? the motor has like 10k miles on it so idk why it just decided to take a dump on me now
Old Jun 25, 2004 | 05:40 AM
grygst76's Avatar
How high did you spin the motor to? I broke the inner damper on one of my springs so it ticks like crazy and I spun it to 6800.
Old Jun 25, 2004 | 08:22 AM
nateh's Avatar
Just had a valve seat break on mine. A sizeable chunk came out (at idle, thankfully) and rattled between the piston and the head. Tore up parts of the combustion chamber, bent a valve and dinged the piston. I think the bottom end is OK. I found the piece embedded in the head when I pulled them.
Old Jun 25, 2004 | 09:00 AM
wdz_lt1's Avatar
ouch thats sux
Old Jun 25, 2004 | 09:13 AM
gb95zconv's Avatar
What kind of spring was it....single ,dual? Are the springs right for you app...ie. will they handle your lift with room to spare, are the seat pressures enough to prevent valve float.
69z-28
Jan 29, 2016 10:46 PM
Z28Freak86
Apr 28, 2015 10:35 PM
ChrisFrez
Mar 29, 2015 09:43 PM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
