Broken spark plug
I was changing my plugs in my 94z28. The plug snapped on the passenger side second from the rear. It broke off at the base. There is nothing there but a hole and then the bottom of the plug. I was told by my mechanic that he could probably get ot out with an extractor w/o taking off the head. Can this be done or am I screwed. They said if they have to take off the head I would be looking at about 600.00.
Did you just break the porcelain off or the whole plug leaving the threaded portion in the head? If its just the porcelain, that is no biggie. If its the whole plug, I don't think I've seen anyone do that before.
Originally posted by ead94z28
Not just the pocelin. The whole friggin plug hex head and all.
-Shannon
If the part that the socket goes on is still there,you should be able to get it out.Spray it with PB Blaster or equivelent.Use a good 6 pt. socket and turn it carefully making sure you are staying square with it.
Originally posted by BUBBA
Or...as Nomad suggested, you might be able to get it out with a large EZ out extractor.
Might want to use some liquid wrench too.
Needless to say, my dad put them back in w/o anti sieze and I had a bear of a time not breaking them off.
-Shannon
Broken spark plug
Thanks for your suggestions. I just bought it not too long ago. The previous owner did not use anti-seize on them. In fact, he replaced the drivers side but did replace the passenger side plugs, for obvious reasons. Anyway, the ones on the passenger side were original AC delco. They had 115,000 miles on them and thats why it broke off, I believe.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
