Broken Dowel Pin
Old Mar 26, 2009 | 03:34 PM
Mystery Bird's Avatar
Thumbs down Broken Dowel Pin
Brought my cam to a shop to have the dowel pin removed and it broke off. The owner said it needed to be drilled out now with a cobalt bit. After it broke I didn't want him to go any further and I took the cam home. This is why I try to do everything myself. It's a Comp Cams 280XFI. Anyone have any suggestions for getting this pin out now without destroying the cam?
Old Mar 26, 2009 | 03:54 PM
Don 97 SS's Avatar
I would have a competent machine shop remove it.
I am curious. Why did you want it removed?
Old Mar 26, 2009 | 04:06 PM
MeanGreen97Z's Avatar
Probably to go to a different length pin.
Old Mar 26, 2009 | 05:01 PM
Don 97 SS's Avatar
Perhaps, but from my limited experience, LT1 engines require a much shorter pin length over other SBC applications. I have had to grind them down, not put a longer one in.
Old Mar 26, 2009 | 05:09 PM
RamAir95TA's Avatar
Vented opti setups require a .700" long dowel pin, non-vented setups requires a .300" long dowel pin.
Old Mar 27, 2009 | 06:07 AM
I had to remove it because it was too short.
Old Mar 27, 2009 | 08:03 AM
Don 97 SS's Avatar
Mystry Bird, that is most interesting. From my research when I did cam swaps, GMPP specifically recommended a dowel length of .620 and Dynaspark recommended a max of .605. How short was yours?
Old Mar 27, 2009 | 10:09 AM
I believe it was somewhere in the .400 range probably for the earlier Opti's, I have a 1995 so I need the longer one.
Old Mar 27, 2009 | 01:48 PM
z28maro's Avatar
im looking for ideas for removing/replacing this pin as well. The machine shop i took it to was unable to remove the old pin by heating it up and tried a few different things but didnt want to risk messing it up by drilling so im open to ideas.
Old Mar 27, 2009 | 02:08 PM
ACE1252's Avatar
I pray they didn't take a torch to it.
Old Apr 1, 2009 | 11:47 AM
Decided this weekend I'm going to give the drive it out from the back a try. I will post with results.
Old Jun 3, 2009 | 04:36 PM
So I just couldn't get it out. I ended up taking a depth gauge and measuring it from behind and realized it was a very small piece left in there. So, I pounded it in from the front all the way and installed new pin.
Old Jun 3, 2009 | 07:17 PM
MachinistOne's Avatar
They come right out with a slide hammer, don't see what the big problem was for them
Old Jun 4, 2009 | 01:45 PM
meissen's Avatar
Interesting - this guy said he had a brand new comp cams cam break the dowel pin too:
https://www.camaroz28.com/forums/sho...d.php?t=690898
Old Jun 4, 2009 | 04:36 PM
Kevin Blown 95 TA's Avatar
My buddies machine shop has a special tool they use to burn out broken taps and stuff like that using spark erosion - it's a kind of EDM - wonder if it would work for busted dowl pins?
