broken bolt help !!
Old Sep 23, 2007 | 08:50 AM
93camarochrisz28's Avatar
Angry broken bolt help !!
well like i said i was torquing down the cam retainerplate bolts and one of the heads broke off what is the best and cheapest way to get this out i really want to finsh my rebuild
Old Sep 23, 2007 | 08:59 AM
94blackz14.2's Avatar
Is it flush with the plate or on the block? If it is the plate just remove the plate and try to grab the little bit that will be sticking out with some pliers or vice grips. If it is flush with the block then I think your next best friend is going to be an easy-out. Plus sometimes when using the reverse direction drill bit it will spin it out as well. Good luck, I know how frustrating those little problems become when all you want to do is finish.
Old Sep 23, 2007 | 09:18 AM
it is a little in side the block but do i get and easy out at an autozone or like a home depo
Old Sep 23, 2007 | 09:35 AM
raroz28's Avatar
I have the Sears craftsman set and it's done me well. The width of the plate should have left enough for you to get some vice grips on it. There is no torque on it so it should be able to be turned out easily.
Old Sep 23, 2007 | 09:44 AM
it broke off alittle bit in side the block
Old Sep 23, 2007 | 09:54 AM
Were you using a torque wrench? They only get 106 lb. in.
That bolt should not be snapping off.
No further suggestions over what 94blackz14.2 said.
Old Sep 23, 2007 | 09:59 AM
yeah and had it set at 106 and i did one and half turns and then the head broke off
Old Sep 23, 2007 | 10:05 AM
I am sure you noticed it is lb. in. and not lb. ft.
There is no accounting for bad luck, though.
Old Sep 23, 2007 | 11:05 AM
no i did not to tell the truth i did not know there was a diff this is the frist motor rebuild ever so i am taking my time what is ther diff
Old Sep 23, 2007 | 11:30 AM
1 lb. ft. = 12 lb. in.
106 lb. in. is less than 9 lb. ft.
If you were using 106 lb. ft. no wonder it broke. That's more than you tighten a lug nut. 9 lb. ft. is just snug.
For the lighter torque stuff, you usually use a torque wrench calibrated in lb. in.
Good thing you now know, so that when you put a new bolt in there, you don't break it off, too.
Old Sep 23, 2007 | 11:42 AM
thank you soo much now just to get the old broken one out
maybe2fast
Mar 16, 2015 09:45 AM
FredM
Mar 6, 2015 03:04 PM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
1LEThumper
Jul 14, 2003 12:45 PM
