broke a rocker stud ???
Old May 19, 2006 | 10:13 PM
jssws-6's Avatar
So I broke a rocker stud ( less than 5000 miles on it ). How much damage do you guys think I should be looking for. So far rocker, and push rod look great. Should I do a full tear down, or just put it back together hope for the best and tear it down in the Winter. Anyone have an extra newer rocker stud standard stock size ???
Old May 19, 2006 | 10:30 PM
z275plus's Avatar
Re: broke a rocker stud ???
If you are using the comp cam pro mag rockers just get the longer studs from arp and problem solved.
Old May 20, 2006 | 08:30 AM
chrism400's Avatar
A very simple compression test in that cylinder will tell you if there are any problems. I'd say in your case, a broken stud probably didn't hurt anything at all other than the stud and pushrod. Roll it on glass and see if it wobbles at all.
13qtr
Oct 28, 2016 08:11 PM
truecontr3
Oct 11, 2015 09:30 AM
DelSoto
Sep 19, 2015 05:31 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
