Broke a lobe on crank pulley flange!!!!
Old Sep 6, 2006 | 09:05 PM
WrecklessZ's Avatar
What are my options?
Cut it till its weak enough to be removed.
Heat it up and hit it with a punch.
I need help.
Old Sep 7, 2006 | 12:15 AM
Heatmaker's Avatar
Advanced Member
Re: Broke a lobe on crank pulley flange!!!!
you broke what now?
Old Sep 7, 2006 | 12:24 AM
bingo's Avatar
You broke the balancer hub? How?
Old Sep 7, 2006 | 05:10 AM
Projectz28's Avatar
Moderator
go to your local auto parts store or a sears and you can buy a puller for $20-30 to remove it the easy way. You will n ot get it off by cutting it... well no time soon anyway. An you run a huge risk of damaging the crank snout.
Old Sep 7, 2006 | 07:34 AM
Sweetred95ta's Avatar
Use a 3-claw puller and grab it around the outside of the pulley. I've removed mine this way many times.
Old Sep 7, 2006 | 09:21 AM
OBE1 95Z28's Avatar
A common mistake people make when using a puller is to butt the center rod of the puller against the hub itself. The center rod must push against the crank snout. I use a smaller diameter allen head bolt that I slip into the center of the crank snout and then butt the puller rod against the head of the allen bolt.
Old Sep 7, 2006 | 04:33 PM
WrecklessZ's Avatar
I was using a puller and one of the lobes snapped off.
Old Sep 7, 2006 | 05:04 PM
Dave89IROC's Avatar
where you pushing on a bolt/rod, or??
courtesy of shoebox
Old Sep 7, 2006 | 05:07 PM
Colin91Z's Avatar
Man that sucks...
but if you need another hub, I have one that'll fit your 95 that I can sell you $35 plus shipping, let me know if you're interested
Sorry for the thread hi-jack
Old Sep 7, 2006 | 06:27 PM
WrecklessZ's Avatar
Colin91Z: Do you have pay pal??
Dave89IROC: I think is was the bolt
Old Sep 7, 2006 | 06:55 PM
ulakovic22's Avatar
If you can't work it off with the puller you can always use a hammer and tap on the back of a good flange until it slides the rest of the way off. Be gentle though.
Old Sep 8, 2006 | 08:38 AM
Colin91Z's Avatar
Yes indeed: nocturnalz28@gmail.com
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
Rde Bandit
Mar 21, 2015 10:17 PM
