Broke 7 top piston rings with cam only LT1?
Old Mar 29, 2009 | 08:08 PM
95LT1Z28's Avatar
My LT1 had severe blow-by towards the end of last year. Around 6,200 rpm's oil would be pushed out the oil dipstick tube all over the engineand I also had white smoke pumping out the oil filler cap. I pulled the engine out and everything looked pretty good no scratches in cylinder walls. As I was pulling out the pistons 7 out of 8 had the top piston ring broken in half! The ringlands on the pistons are fine, just have the broken top rings. What would cause the top rings to break into 2 pieces on a cam only LT1 engine? I have about 10,000 miles on this setup and the engine was still running great besides the white smoke from the oil fill cap. I have a XE 224/230 with supporting mods and a PCMforless mail order tune. I am going to rebuild the engine, but would like to know what caused this to happen so it doesn't happen again!
Jeff
Old Mar 29, 2009 | 08:09 PM
wrd1972's Avatar
Are you sprying?
May have been detonation.
Old Mar 29, 2009 | 08:16 PM
95LT1Z28's Avatar
Nope, no spray or boost ever - just a cammed, naturally aspirated LT1.
Old Mar 29, 2009 | 08:45 PM
93Z28Sam's Avatar
Incorrect ring gaps could have caused your problem. Maybe they were too tight. What did they set the gaps at?
Old Mar 29, 2009 | 08:48 PM
96capricemgr's Avatar
Good chance it was too lean with too much timing.
Old Mar 29, 2009 | 08:55 PM
95LT1Z28's Avatar
The motor was bone stock from GM when I did the cam upgrade, engine only has 86,000 miles. I could see too much timing or running too lean, maybe I will get with Bryan at PCMforless so he can recheck the fuel and timing just to be on the safe side.
Old Mar 30, 2009 | 12:06 AM
GMRL's Avatar
Did it ever overheat or run low on coolant? Besides detonation, thats one of the leading causes of ring failure.
Old Mar 30, 2009 | 01:24 AM
87bandit's Avatar
get that thing on a dyno when you fix it, no reason to reuse the possible source of your problem imo
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
1963SS
Feb 6, 2015 10:05 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Queens94z28
Nov 20, 2014 06:03 PM
