broke 2 push rods and a lifter
Old Apr 18, 2006 | 10:12 AM
camaroKid223's Avatar
I broke 2 stock push rods (thought 95 had hardened?) and a comp r lifter (big suprise right). Any way I plan to drain the oil and replace all the rods and lifters this weekend. I was thinking comp hi-tech 7.2 push rods but really have no idea for a lifter to run with the mods in my sig. Any help?
Old Apr 18, 2006 | 10:32 AM
Javier97Z28's Avatar
Moderator
Re: broke 2 push rods and a lifter
oem style replacement lifters from comp would do the trick. even the summit branded ones would be fine.
Old Apr 18, 2006 | 10:35 AM
will the oem style take high rpm's? I have been taking this motor up to 7000 or higher. I havent had the chance to put in the 3.73's yet but with 2.72's and a high rpm you can stay in second gear through the 1/4
Old Apr 18, 2006 | 10:40 AM
Moderator
Well, if your budget allows, Morel lifters are the best $ can buy.
Old Apr 18, 2006 | 10:43 AM
do you have part #'s for the oem style and the morels? Am I right for the push rod choice?
Sorry for all the questions, I just want to have the motor back up and running this weekend, and want to do it right.
Old Apr 18, 2006 | 01:26 PM
How would these comp high energy:
http://www.jegs.com/webapp/wcs/store...tegoryId=16685
Old Apr 18, 2006 | 01:31 PM
BlackScreaminMachine's Avatar
Morels will require a shorter pushrod, what you need is a morel lifter, and a pushrod length checker and figure out what size is needed, I have morels, with LT4 head gaskets and the heads have been decked once... came out to 7.000" Comp cam Hi Tec pushrods
Old Apr 18, 2006 | 01:54 PM
who carries morels, and how much do they cost. I dont want to put a junk motor together but if comp oem's will wrk fine and the morels are 10 times the cost its going to be hard to justify to my budget.
Old Apr 18, 2006 | 03:33 PM
Bret Bauer has them in stock, or I know thunder racing carries them, but bret is cheaper.
Old Apr 18, 2006 | 06:50 PM
30AnvZ28's Avatar
I got my Morel drop in styles from Victory Racing. They were $500. Not in stock either... had to wait a week or so. If you want 7.2 Comp Hi-Tech pushrods... I have some. I need shorter ones due to the Morel lifters. If I can help let me know.
30AnvZ28's Avatar
Old Apr 18, 2006 | 08:28 PM
wrd1972's Avatar
How fast was it revved?
My 95 definitelt did not have hardened push rods, dod not pass the file test.
Old Apr 18, 2006 | 08:38 PM
it was prob above 7000 4 times the night before they went out
oldschool
Feb 9, 2016 09:21 PM
KamikaZ28
May 28, 2015 12:45 AM
nikolt1
Feb 27, 2015 09:10 PM
ModdedNerd
Feb 5, 2015 04:37 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
