Breather Needed?
Old Aug 16, 2009 | 12:13 PM
TheChronic's Avatar
Breather Needed?
On my LT1 I have an AS&M throttle body without the port for the breather tube from the PS valve cover. Can I just plug the hole in the valve cover -- or does there need to be some sort of ventilation?
I will be maintaining the PCV system on the intake.
Old Aug 16, 2009 | 12:39 PM
WS6T3RROR's Avatar
It needs a breather to function properly, or you could just hook up a rubber line behind the maf sensor in the intake duct. Pretty much doing the same thing, but i prefer the breather to keep oil out of the intake.
Old Aug 16, 2009 | 01:21 PM
If you plug the ps valve cover, you basically kill the PCV system, as it will get no air. Since you have no air source from the TB, just put a breather on the valve cover.
Old Aug 17, 2009 | 09:51 PM
TheChronic's Avatar
Thanks guys!
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
CobraEatr
Jul 23, 2002 06:32 PM
