brand new engine done and won't fricken fire up
Old Mar 16, 2005 | 12:19 AM
  #16
Pasky's Avatar
Re: brand new engine done and won't fricken fire up
Got it running .
Old Mar 16, 2005 | 12:39 AM
  #17
turbo_Z's Avatar
And the problem was....?
BTW if you havent changed the injector constant to around 42 yet then you will notice the motor running very rich.
Old Mar 16, 2005 | 02:21 AM
  #18
94heritageZ's Avatar
Yea what was the problem
Old Mar 16, 2005 | 06:51 AM
  #19
HaynesFaithZ28's Avatar
Your Valves are not adjusted correctly. I rebuilt my motor 4 months ago and I went through the exact same problem. My valves were too tight and therefore I had no compression. Double check your valves and I promise the beast will start. Use the EIOC method, when the Exhaust Valve opens adjust the Intake valve and when the Intake valve closes then adjust the exhaust valve. After you get it running you can fine tune the valves with the engine on and revved to 1,500RPM. This will give you a smooth valvetrain. Good Luck!
Old Mar 16, 2005 | 11:57 AM
  #20
Pasky's Avatar
Had a o-ring leaking on 3 injectors, the constant has been changed. It fired up after I replace some o-rings .
Old Mar 16, 2005 | 12:50 PM
  #21
1-bad-z28's Avatar
the simplest things sometimes
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Jazsun
Dec 29, 2014 12:14 PM
Catmaigne
Dec 25, 2014 12:16 PM
