brakes/bleeding
Old Mar 31, 2004 | 07:51 PM
CamaroSS30thAnn's Avatar
brakes/bleeding
ive had my car on a lift with no brakes on them foe a few days now......i have the lines ziptied with baggies and dont have alot of fluid in the front bags but some in the rear
i know i am goona have to to blled the crap out of my brakes
anybody have any input or advice about bleeding brakes...
if i get air in the ABS unit am i looking into some trouble?
thanks guys
Old Mar 31, 2004 | 07:57 PM
97RedT/AWS-6's Avatar
As long as you keep your master cylinder filled up, the only thing you'll need to bleed will be the calipers. When changing my brakes, I did a complete bleed and have had no problems.
Old Mar 31, 2004 | 08:00 PM
1msfyter's Avatar
MitiVac handpump . start with the passenger side rear and bleed twice. Ive done my many times.
Old Mar 31, 2004 | 08:06 PM
if i did get any air in the ABS can i still bleed the brakes without a visit to the local dealer or shop?
Old Mar 31, 2004 | 10:56 PM
Yeah, it shouldn't be a problem. There are bleeder screws on the ABS unit. You should bleed the ABS unit, bleed your brakes, then bleed the ABS unit again. Twice is always better than once
