brake probs with pics
well u got a few things to check, do u have enough fluid in there?
should be pretty much brim full under the hood drivers side above the wheel...
if thats full i donno what else it could be besides a bad sensor, the sensor i dont belive keeps track of the pads...
check to see if the sensor on the break pad is touching... it should be obvious what it is it will be on the upper portion of the break pad, if its not touching your still ok with those...
just check ur fluid
just check ur fluid
Originally posted by Transamdriver
Your pads are gone, the wear on the rotor looks like they have been scorched.
well, i just got the car yesterday, so i had no time to change them yet... i was asking if it could be anything else
no, i'm not saving weight
it was like that when i got it yesterday, and i wish that was my least problem... i'll get some nuts for it :P
i'll change the rotor most likely too...
i just hope its not a sensor or something
it was like that when i got it yesterday, and i wish that was my least problem... i'll get some nuts for it :Pi'll change the rotor most likely too...
carguyshu
Jan 22, 2017 11:19 AM
May 1, 2015 01:14 PM
