Brake Light re-adjusting
Old Jun 30, 2004 | 07:55 PM
25thBird's Avatar
Brake Light re-adjusting?
My brake light is on, and I'm pretty sure my emergency brake needs to be re-adjusted at the calipers. How hard is it to re-adjust the e-brake?
Old Jun 30, 2004 | 11:35 PM
25thBird's Avatar
anyone?
Old Jul 1, 2004 | 12:08 AM
The procedure is not very common and likely won't put the brake lamp out. It should not be done unless new brakes have been installed. Have you done recent work on the brakes?
Old Jul 1, 2004 | 01:22 AM
25thBird's Avatar
I took off the calipers to do a gear swap. When I put everything back together, the light was on. While putting one of the capipers back on, one of the pads came off, and I had place it back on. There's nothing else I can think of that I did.
Old Jul 1, 2004 | 08:29 AM
I wouldn't touch the parking brake stuff. It has to be something else. It's the brake light and not the ABS light? Are you sure you did not cause a leak somewhere?
Old Jul 1, 2004 | 07:25 PM
25thBird's Avatar
Yeah, it's the brake light not the abs light. I'm pretty sure there are no leaks. My frined told me it's probably because he left one the calipper hanging for a bit, during the gear swap; and thinks, that might have caused the e brake line to tug a bit and cause the light to be on.
Old Jul 1, 2004 | 09:07 PM
25thBird's Avatar
Is that possible?
Old Jul 1, 2004 | 10:42 PM
Not really, unless it leaked. It might have sensed a pressure differential. A hard press on the brake pedal will reset the brake lamp if that is the case and the differential does not still exist. Press down hard on the pedal until you hear/feel a click.
Old Jul 2, 2004 | 02:03 AM
25thBird's Avatar
Sweet, I'll try that. Thanks.
Old Jul 2, 2004 | 09:02 PM
25thBird's Avatar
Took a couple of tries, but it worked! Thanks again
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
